Member
0 Kudos
Post 1 of 4
Assembly not showing in cross sections
1358 Views, 3 Replies
01-21-2013 07:39 AM
I have everything needed for plotting of cross sections. Alignment, profile, assembly....
The "Corridor Section Editor" shows everything as it should be. Existing Ground, Final Grade, Labeling, etc...
When "Create Multiple Views" or "Create Section View" only existing Ground shows. All layers are on...
Any ideas..
Have you sampled the corridor?  Under group properties, the sections tab has a 'sample more sources' button (top right had corner) open it up and you will be able to add or remove objects to your section views.
Member
0 Kudos
Post 2 of 4
Re: Assembly not showing in cross sections
01-21-2013 07:40 AM in reply to: audave
BTW When plotting sections, in the "Section Display Option"  Existing ground is the  only thing showing, what am I missing, Thanks
Active Member
1 Kudo
Post 3 of 4
01-21-2013 10:12 AM in reply to: audave
Member
0 Kudos
Post 4 of 4
01-21-2013 10:57 AM in reply to: Wanita17
That was it! Something simple as usual!!
Thanks!!
