AutoCAD Civil 3D General Discussion
Member
0 Kudos
Post 1 of 2
assembly for multiple open cut condition
203 Views, 1 Replies
06-05-2013 03:53 AM
I have an open cut area with 8 meter height and a bench of 5 meter for the first 3 berm, on the 4th berm the bench will become 10 meter. Is there any way to build it in assembly? I attached 2 drawings to clarify the problem.
*Expert Elite*
418 Kudos
Post 2 of 2
Re: assembly for multiple open cut condition
06-06-2013 08:52 AM in reply to: rodney111
It should be possible to do this using a series of ConditionalCutOrFill subassemblies and generic links.  You need to work out the logic of the steps first, then you can add the subassemblies to the drawing.
Starting at the outside of the first bench:
1. If this point is in fill then build a fill slope.
2. If this point is in cut then move to the theoretical location at the outside of the next bench.
  3. If this point is in fill, then move back to the previous point and build a simple cut slope to daylight.
  4. If this point is in cut, then move back to the previous point and build the slope and bench.
5. Repeat the cycle from step 2.
You're going to end up with a whole series of conditionals and generic links strung together.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Post to the Community
New Post
