I have created Alignments, Design Profiles and Assemblies. From these, I created a corridor. I see that the Assembly Base is not following the design profile but stays at zero elevation all along. Any idea what may be the reason.
Is MC00-FRL the design profile? And that profile has data between 0+000 and 2+270,the region extents?
Post your drawing.
Post the drawing.
Your drawing is nothing but lines; there are no alignments, profiles, assemblies at all. You must have used ExporttoAutoCAD.
Just post the drawing as it is, without exporttoautocad. If it's too big, use a file sharing service. You can send small files for free on Hightail.com and maybe Dropbox. Use my email address: support at deltaengineeringsystems dot com or post your dropbox link here.
Tim
If you look at the Profile View MC00, it only shows two profiles: ClientOGL-Surface(9) and one with no name. The profile called MC00-FGL only exists in the prospector and shows minimum and maximum elevations of 0.00.
Go into the properties of the magenta profile and assign a name. Go to Corridor Properties and assign that profile instead of MC00-FGL. Now your assemblies will elevate correctly.
Best regards,
Tim
That was the perfect solution. Thanks a lot.
Just out of curiosity. I have created some 20 Profiles in this job using the same workflow. How come only a few profiles did not register properly whereas others did?
Just out of curiosity. I have created some 20 profiles in this job. How come a few did not register properly whereas others did?
Just out of curiosity. I have created some 20 profiles in this job following the same workflow. How come a few did not register properly whereas others did
