trynders
Message 1 of 3 (179 Views)
Assemblies and corridors
179 Views, 2 Replies
12-28-2012 12:50 PM
Okay all, here is my next question.  I have a proposed road with a varying curb line.  There is a minimum 5 foot tree lawn between the back of curb and sidewalk.  I have used a lane transition and attached it to an alignment to get the curb to follow.  Also used the urban sidewalk with buffer widths.  How do I connect the back of curb to the sidewalk and keep the sidewalk in the same offset from the baseline.  In the attachment, I have used a zero inside boulevard width and slide the sidewalk over from the curb line in my assembly.  Will this work?
Happy new year all
Jeff_M
Message 2 of 3 (168 Views)
Re: Assemblies and corridors
12-28-2012 01:35 PM in reply to: trynders
That would work, except you lose the Top codes connection and may confuse a surface build. I use a polyline at the edge of sidewalk and assign that as a horizontal target for the inside edge of the sidewalk.
Valued Mentor
fcernst
Message 3 of 3 (155 Views)
12-28-2012 03:38 PM in reply to: trynders
I would use an Offset Alignment as the Target.
It's quick to Create and will dynamically follow the baseline at the offset distance should the baseline have to move around.
Fred Ernst, PE
C3D 2015
Ernst Engineering
www.ernstengineering.com
