Civil 3D Forum
area command
6 REPLIES 6
wbrustle
1373 Views, 6 Replies
area command
I was just wondering why when I try and calculate an area using a polyine, I am getting a readout of 1.80401967E+07, when I have it set to give me the calculation in square feet? It is an area of approx. 246 Acres.....is this because the area is so large? I am not sure what the "E" stands for or the "+07" at the end..............thanks
6 REPLIES 6
Joe-Bouza
in reply to: wbrustle
the E stands for exponent that number is 1.80101967 x 10 ^7 -  divided by 43560 is 413 acres
Your Name
wbrustle
in reply to: Joe-Bouza
ok......can you explain more how you got the 413 acres. Maybe you could type out how you used the exponent (multplied it)....thanks
rkmcswain
Set LUPREC to a lower value (try 2), then run your Area calc again.
I suspect LUPREC is currently set to 8, and AutoCAD will only show you ±15 number of places in number. So by reducing the precision on the back end of the decimal point, you will be able to see the full number on the front side of the decimal point.
Below is an example. Same polyline.
wbrustle
in reply to: rkmcswain
thank you so much!!! setting that variable to "2" solved my problem
ericcollins6932
An acre is one chain by 10 chains, where 1 mile = 80 chains. So 1 chain by 1/8 of a mile.
1 chain = 66 feet.
66' * 660' = 43560 sq. ft = 1 acre.
Eric Collins, P.Tech.(Eng.)
Win 10
Intel i7 9700 @ 3 GHz
16 GB RAM
Civil 3D 2019
wfberry
Just move your decimal 7 places to the right and you have square feet.
Bill
Rail Community
