Civil 3D Forum
area annotation / fields
15 REPLIES 15
Message 1 of 16
lambertb
2433 Views, 15 Replies
I have a bunch of polylines I want to display the areas for. I am using mtext and fields. Howver the fields format part always defaults to a less than desireable format. Is there a way to set the formatting how I want it for the entire file? Or is there a better way of labeling than fields? Thanks.
C3D 2022 and 2024
15 REPLIES 15
Message 2 of 16
jmayo-EE
in reply to: lambertb
An item for the wish list...
You can get around this if you can use a table to report the areas... If the cells all have the same format they can be edited together from the properties dialog.
John Mayo
Message 3 of 16
jmayo-EE
in reply to: jmayo-EE
When I cna't use tables I use C3D labels. They will get the area of a pline.
John Mayo
Message 4 of 16
jmayo-EE
I think to fast for my fingers...cna't should be can't
John Mayo
Message 5 of 16
lambertb
Which label? I have a basic knowledge of them but maybe didn't dig deep enough to find one regarding area.
Thanks.
C3D 2022 and 2024
Message 6 of 16
neilyj666
convert them to parcels?
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 7 of 16
jmayo-EE
Line/Curve labels.
John Mayo
Message 8 of 16
jmayo-EE
in reply to: neilyj666
That would work real nice as well Neil. I would just make sure there are no overlapping plines that wold create overlapping parcel segments. If the OP likes that avenue then MAPCLEAN may be of use to cleanup duplicate objects.
John Mayo
Message 9 of 16
jmayo-EE
A few examples.
Also note that if you need to sum the areas you may just want to use the table or a hatch. A hatch will sum the areas  even if they are disconnected. The resultant area can be reported with one field.
John Mayo
Message 10 of 16
Joe-Bouza
Alignment pushed to a site make good area parcel and elliminates the overlapping conundrum Smiley Happy
Joe Bouza
Message 11 of 16
neilyj666
Additionally, I think I'd copy/wblock the polylines to a new drawing and then do any MAPCLEAN and parcel creation there as I've had bad experiences with parcels in the past....:)
Message 12 of 16
neilyj666
in reply to: Joe-Bouza
...especially useful for identifying areas of widening as well...:)
Message 13 of 16
neilyj666
John
Can you explain how to do this as I can't see how it could be done?
Message 14 of 16
Joe-Bouza
It is - isn't it <G>
Joe Bouza
Message 15 of 16
Joe-Bouza
Create a line lable style under General>>Multipurpose>>Line
Joe Bouza
Message 16 of 16
neilyj666
Neat technique and dynamic too ... 🙂  I'm putting that in my template right now....
Rail Community
