Is there any way I can get a hold of your RCP ARCH Pipe Catalog?
Thanks.
I do work for Jacobs and I believe we are still a solution partner with Autodesk. However, I cannot share my catalog because it was built on company time. Making it a proprietary document that I cannot share.
If anyone still needs help with building these parts I would be more than willing to help. They key is using the unbounded lines to hold the shape. I'm posting a pic of my elliptical and arch pipes to show what I'm talking about.
I was able to create a Pipe Arch part family based on standard CMP sizes from CONTECH. Alonzom_90, I do not know if this solves your problem, but let me know.
To install, create the directory C:\ProgramData\Autodesk\C3D 2016\enu\Pipes Catalog\US Imperial Pipes\Arch Pipe, copy the .zip into this folder, extract. You will then want to fire up CAD, run "partcatalogregen," and select "Pipes." Create a new part family in any part list you have (storm sewer?). You can easily add all sizes as they are configured in a table.
Thank you very much for sharing your arch pipe file. It just so happens that I am currently working on a culvert design project using an arch pipe from CONTECH and your file has saved me many hours of work and frustration trying to fumble around in Parts Builder. Thank you so much!!!
Any chance you've done a similar thing with the CONTECH arch pipe end sections?
I do not, but when/if I complete them I will certainly share them. My current solution has been a "dumb" 2D style.
I did find a great CMP end section part at one point (see attached). That's where I would start for the pipe arch end section, but honestly I'm not sure if that is the right approach.
@Avera737 Thank you for posting your Catalog!
Unfortunatey I am still having the same problem.
I uploaded your zip file, added it to my part directory, ran partcatalog regen, went into my parts list added the part family and the different pipe sizes.
I go and create a pipe network and this is what i see.
In plan view the pipe has the wrong dimensions. and actually it doesnt matter what pipe you size you choose they all shopw up with 17' width. I wanted to model a 71" S x 47" R CMP. instead the pipe gets drawn at 17ft in plan view.
I proceed and give my pipe inverts of 0.00' both ends.
In my sections view my pipe looks great. the inverts match and the pipe height is correct.
when I draw the pipe in a profile view the pipe looks good to but its drawn with the wrong dimensions and it had the incorrect invert.
I am currently working on a big project (62 miles long) with 110 culverts. We have multiple firms working on it and its important that when the pipe is drawn and the data shortcut is created the pipe needs to have consistent invert/shape and dimensions for the plan, sections and profile views.
What i have done currently is i modeled concrete boxes to accomodate for the rise vs stand difference. in profile view they look incorrect but if there is no way around this we may just hand draw them in the profiles where we need them. The project is at a 30% design.
I've tried reading up on parts builder and trtied creating a part family but i was unsucesseful. If anybody out there has any tips or suggestions its greatly appreciated.
Thank you.
C3D 2015
Thank you.
C3D 2015
alonzom_90,
Try running "partbuilder," open the pipe arch family, run "units," set to inches, save the part family (using the icon in the sidebar), and refresh the library.
You may need to create the parts again in your template, but this should resolve the issue. I must have inadvertenly changed that before uploading the family.
Let me know how you make out.
Is anyone aware of any updates to this post in the last 8 years?
I am interested in a Contech 10 ft X 3.5 ft high open bottom arch pipe.
Has anyone created a pipe network part family for this?
Anne -
Feel free to pull this and modify https://github.com/MattAndersonPE/Civil-3D-Catalog/tree/master/US%20Imperial%20Pipes/Arch%20Pipes
I never got around to the open-bottom pipes.
Thanks Mat.
Are these just the standard CMP small arch pipes? I might have a use for those on another project.
The project I am looking at is a 10 ft wide by 3.5 high open bottom pipe.
Yes, those are standard arch pipes - either concrete or metal.
To save me the research - email me the family geometry...
Matthew.Anderson.pe at gmail.com
@KEStewart wrote:
OK - Maybe I am missing something - but after building an arch pipe on my own, and also after using the example provided on this thread (arch.zip) by davelglen - I am coming up with the same problem...
My arch pipe is not showing up at the correct elevation in profile or section.
I'm sure that this is probably because of the way that Part Builder defines the arch pipe, but I am curious if anyone else has encountered this, and if they have conquered it, what was the remedy?
Thanks in advance,
Kevin
This part is flawed. It doesn't know where the invert is. When you swap part it changes the invert of the pipe. Does 2017 have a working Arch Pipe part?
