Civil 3D Forum
Arc Lables not spacing degree symbol enough
4 REPLIES 4
350 Views, 4 Replies
I am in C3D 2012 and using Romans.shx for my text.  When labeling an Arc, the degree symbol comes out too close to the following text/number.  Is there any way to adjust the spacing on curved text.  On a straight line it looks fine.
Dave
4 REPLIES 4
wfberry
Just add a space in your label.  You may have to have two labels, one for tangents and one for curves.
Bill
in reply to: wfberry
Nice idea, but the bearing is one field, DD.MM.SS.  There is no way I know of to insert a space into the field.  I tried using the "spaced" option, but that spaces all of the elements to far.  The only other way I can think of is a series of expressions for the Degrees, Minutes and Seconds as individual entries.  I may give that a try.
Dave
Jeff_M
Dave, no need for an expression. The Label Style Angle property has an Output modifier so you can split it into the separate components DD MM SS:
in reply to: Jeff_M
Excellent.  Thank you, once again.  I tried a regular spce, but it was too big.  I then tried the non-breaking-space and it worked just right.  I didn't know that modifier was there.
Dave
Rail Community
