I am in C3D 2012 and using Romans.shx for my text. When labeling an Arc, the degree symbol comes out too close to the following text/number. Is there any way to adjust the spacing on curved text. On a straight line it looks fine.
Dave
Nice idea, but the bearing is one field, DD.MM.SS. There is no way I know of to insert a space into the field. I tried using the "spaced" option, but that spaces all of the elements to far. The only other way I can think of is a series of expressions for the Degrees, Minutes and Seconds as individual entries. I may give that a try.
Dave
Excellent. Thank you, once again. I tried a regular spce, but it was too big. I then tried the non-breaking-space and it worked just right. I didn't know that modifier was there.
Dave
