alignment, profile, assembly and corridor have been setup. i have setup the superelevation calcuations and did the super elevation view and it looks right, but for some reason the super elevation won't apply to my section view assemblies or the corridor editor. any ideas?
Which version of C3D?
Which subassembly are you using for your lanes?
First off make sure the sub assembly you are using can in fact utilizes superelevation
Secondly if the sub assembly can utilize superelevation make sure it is set to use laneinside or similar and not set to none as is some of the sub assemblies by default.
Hi!
I have same issue!
I'm using 2013 ver. of C3D and also have calculated superelevation for undivided planar road with LaneSuperelevationAOR subassamblie.
Superelevation View seems good but can't get it in section view.
Subassamby parameters:
L R
Use Superelevation : Left Lane Inside Right Lane Inside
Slope Direction: Away from Crown Away from Crown
Potential Pivot : Yes Yes
Outside Point Code: None None
Assambly is set as Undivided Planar Road...
