Civil 3D Forum
Applying levels from a surface model to an alignment profile
6 REPLIES 6
1168 Views, 6 Replies
Hi guys
Do any of you guys know how i can apply the levels of an existing road (taken from a topographical survey) and applying them along an alignment string.
Regards
Dan
6 REPLIES 6
Pointdump
Dan,
"...and applying them along an alignment string."
I totally do not understand what you're trying to do here. More information, please.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
Do you want to do a 3d surface?
in reply to: Pointdump
I have a existing carriageway that I would like to tie a proposed carriageway into, the existing carriageway has been surveyed and I have modeled it into a surface.
Along the channel the exisitng carriageway that the new carriageway is to join onto I have created an alignment that will be the width and level target for the proposed corridor.
Previoulsy when producing the profile of the existing carriageway channel alignment I would try to match the existing by drawing the profile by hand, obviously it is time consuming and quite difficult to get an exact match, is there a way of telling Civils 3D to match the profile of the proposed edge of carriageway channel with the existing edge of carriageway channel.
Hope that makes sense
Regards
Dan
Lisa_Pohlmeyer
There is a method to import a profile from a file, I believe it's on the Ribbon.  If they're just points, you can import them to your drawing, then project them to the profile. And, if you have a surface, you can just sample that surface and add it to your profile view.
Lisa Pohlmeyer
Civil 3D User
Website | Facebook | Twitter
AllenJessup
If you have already built the Surface. Create an Alignment using the appropriate Alignment Creation Tools.
Then createa a Profile along that alignment using your existing Surface.
Draw that Profile in a Profile View. In this case Draw means a process in the Profile creation. Not manually drawing the profile.
Allen
Allen Jessup
CAD Manager - Designer
in reply to: AllenJessup
Cheers Allen,
That is exactly what I wanted, i didnt realise that you can use the Profile as a profile without drawing a new alignment on it. Now i can use it to tie my proposed road into the existing road.
Regards
Dan
Rail Community
