Hi
Now i created my corridor with frequency 3 meters.I edited many sections in the corridor section view.( using parameter editor, delete points, delete links etc..) After everything finished i realised that i need to decrease the frequency to 2 meters.When i changed the frequency to 2 meters, most of the overridden stations are lost and all my corridor was messed up?
It would be nice to apply the manual changes to a region instead of stations.Becouse stations can change?
I guess you need to use the apply station Range tool in the section editor. See attached Image. At the first station make the changes, using the apply station range button; the Start station will usually be the one where you have edited, then end station will be the last station of the Range (see the shots)
Sorry for the missunderstanding..My point is; i have done my edits and finished "apply station range" for 5 meters frequency, later i needed 4 meters frequency for my corridor..When i change it to 4 then the coridor is messed up...
o.k i think I get you there and think we share that problem. I am also usually forced to prepare to do my edits all over, in case I find I need to change any corridor parameters. Hope there's something out there to work around that
