Can I apply a default style to points with a raw description not in the description key sets?
When I import survey points into the drawing my description keys will assign specifed styles (and therefore layers) to descriptions it recognises, and a default style (and layer) to ones it does not recognise.
Then if i change raw descriptions in the drawing I can "Apply description keys" and have the styles and layers change based on the changes I made to the raw description. This is fine for descriptions in the key set.
Can I get Civil3D to apply the default style to points that did have a description that is in the DKS but has now been changed to one that is not? As it works for me now, these points remain unchanged in there layer and style.
Regards
Solved by mathewkol. Go to Solution.
The way I have it set up, any point that essentially has no desc key assigned will be assigned the Basic style. If it was TREE, it would get the tree symbol, if I change it to ABC then apply desc keys, it will change to Basic.
The trick is to add two new dwsc keys; @* and #*. The @ catches any that begin with letters, the # catches any that begin with numbers.
CB,
Not sure I understand. Why don't you want to just make another Description Key for the changed Raw Descriptions?
Dave
Dave Stoll
Las Vegas, Nevada
Yes you could make another description key for those points, but doing as Matt suggests helps the user see that either another description key needs to be set or that they need to be coded differently. I have the description keys @* and #* go to a layer "unrecognised points" and with a style that stands our visually so they can be easitly identified.
Great work Matt.
Cheers
Sorry Matt.
It appeared to work for me, but I have just discovered that @* is matched before any specific one letter codes.
For example I have "F*" for fence points, but these codes get caught by @*.
So @* and #* do work, but only as long as the minimum length of the other description keys is a minimum of two characters.
Does this sound correct?
Regards
