Civil 3D Forum
APPEND TO COGO POINT DESCRIPTION
2 REPLIES 2
MonkeyTrainer
375 Views, 2 Replies
I have a couple hundred cogo points with all different descriptions. is there a way to add "use these" to the beginning of all the nodes at once?
2 REPLIES 2
Jeff_M
in reply to: MonkeyTrainer
Yes. Select the points, or have a Point Group with them in it, Edit the points, select all in the Panorama, right-click the header for Description Format, select Edit, place this in the edit box:
use these - $*
hit enter. All of the Full descriptions will then have the "use these -" plus the raw description. Now, if you already use the Full description modifiers, then you might need to go about it a bit differently. i.e. programatically.
MonkeyTrainer
in reply to: Jeff_M
that worked great, thanks Jeff.
Rail Community
