Civil 3D Forum
Anyway to convert a group of Lines to Polylines
7 REPLIES 7
Message 1 of 8
9405 Views, 7 Replies
On several occasions I have had to convert a group of lines to polylines but had to select and convert each line one after the other. Instead of one after another is there a way or a command to select all the lines and convert them as group into polylines?
7 REPLIES 7
Message 2 of 8
Mark_Castle
Type pedit, select multiple, pick all of the lines you want to convert, type Y when asked if you want to convert them to polylines, exit command.
Mark Castle
Win 10 64-Bit, Thinkpad P50
16 GB RAM; Core i7-6820HQ; Quadro M1000M
Message 3 of 8
BrianHailey
Even easier (if you are on 2012 or later - or was it 2011?); Grab the lines and type J at the command line.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Message 4 of 8
Joe-Bouza
in reply to: BrianHailey
and get what?
I'm left with lines. Is there more to it?
Joe Bouza
Message 5 of 8
To convert the lines into polylines, they have to be touched end to end .  the pedit command will turn the series of lines into one pline, not multiple
Surveyor Lee
Message 6 of 8
Joe-Bouza
Thats only to join them. PEDIT M will convert a collection of geometry
Joe Bouza
Message 7 of 8
Alfred.NESWADBA
and if you want to do some cleanup don't forget you have the Map3D-functionality included, therefor the command _MAPCLEAN (>>>details<<<) can help a lot!
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
Message 8 of 8
BrianHailey
in reply to: Joe-Bouza
@Joe-Bouza wrote:
and get what?
My bad. I missread the original question. To join them, use J. To simply convert them, use MPEDIT (you can select them first and then run MPEDIT whereas if you run PEDIT you must select them after the fact).
GEI Consultants
My Civil 3D Blog
Rail Community
