I think tool palette with vertical tabs are a lot of unconfortable...
Is there any way to have or to create a "mega-subasemblies-ribbon" ?
Civil 3D (2013) how much you have to improve....
I don't know of any way to do this with the out of the box configurations on the ribbon but I'm sure with some customizing it should be possible. Basically, create a tool that inserts a block and then explodes it and then add that tool to the ribbon (the block would contain the subassembly).
If I understand the request, you can add custom assemblies and subassemblies to a palette. I don't know if they can be added to a ribbon.
But ... the vertical texts, the little icons....
It is not easy to use ....
