I want to export my slope - table - legend to an excel or txt file.
(Of course only the values)
Any idea ? Thanks
Solved by neilyj666. Go to Solution.
Explode it a few times until you are left with lines (NOT polylines) and text/mtext and use the attached lsp to convert to AutoCAD table, then export to excel etc as usual
This functionality should be available OOTB
neilyj (No connection with Autodesk other than using the products in the real world)
@lakshmikanthr22 There is a very useful tool from @TerryDotson of Dotsoft that will do this job very nicely - it's one of the first Add-ons I install
Civil Table Tools | Autodesk Civil 3D | Autodesk App Store
I have updated the solution to use a free add on from @TerryDotson of Dotsoft
An import caveat before using this tool is below from the help info
