Civil 3D Forum
Any way to delete the labels of a particular alignment ?
10 REPLIES 10
Message 1 of 11
tonnot
2041 Views, 10 Replies
Or maybe I have to delete it individually ?
Is not an option to "delete aligment labels"
Civil 3D (2013) how much you have to improve....
10 REPLIES 10
Message 2 of 11
wfberry
in reply to: tonnot
Normally selecting one object and deleting it will remove all similar objects. Selecting this same object with the "ctrl" key depressed will only remove the one object.
Bill
Message 3 of 11
tonnot
in reply to: tonnot
But... If I want to delete all the labels of a 14 km lenght highway?
Autodesk boys, please.....
Thanks anyway
Message 4 of 11
neilyj666
in reply to: tonnot
Can you achieve this with Label Sets i.e. have a _No Display one?
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 5 of 11
tonnot
in reply to: neilyj666
It could be a solution.
But ... I think we need a "global" project navigator...... (or somehing like this....)
Message 6 of 11
Jay_B
in reply to: tonnot
"But... If I want to delete all the labels of a 14 km lenght highway?
Thanks anyway"
Delete means to erase or remove from drawing , are you looking to delete the labels or just turn off the display?
Not sure I'm following your workflow but as has been mentioned "SELECT SIMILAR" should work for deleting ALL Alignment labels (may have to repeat several times or multiple object selection if entity types differ),
No_Display styles work well for turning them off.
Proper Layer management for alignment labels also helps to quickly turn them off.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Message 7 of 11
Neilw_05
in reply to: tonnot
How were these labels created? Are they applied from a label set, such as for station labels? In that case the station labels behave as one object. As Bill Berry mentioned, if you select any one of the station labels and hit delete, they will all be erased.
Now if you placed individual labels using the Annotation tool then they do not behave as a single object and you will have to use one of the selection set and filtering methods provided in Autocad such as QSELECT, FASTSELECT, FILTER and such.
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
Message 8 of 11
tonnot
in reply to: Neilw_05
No, no ,. no........
The "natural" way of work (i think) is to view labels for radii,  clothoid values an stations for these, while you are working in your desing.
The only way to do this is using "labeling", because the -label set- or the style- does not offer me a way to label radiis and spirals, isn't ?
So, in case I dont like the initial design or simply a want to change the labeling style I need to delete it previously, isn't it ?
So, finally, it should have a way to quicky  delete, activate-deactivate or change this label style.....
Thanks.
Message 9 of 11
troma
in reply to: tonnot
You could try this:
http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Delete-all-labels-on-a-Feature-Line/m-p/3767186#M1947...
I have no idea if it will work or not, but sounds like it might.
Mark Green
Working on Civil 3D in Canada
Message 10 of 11
Neilw_05
in reply to: troma
Jeff's tool does do the job. Run the tool, pick the alignment and all length, bearing and curve labels go away. Oddly it does not remove station and geometry point labels. That might be a good thing.
WIN 10 64 PRO
Message 11 of 11
tonnot
Thanks, I'm going to try .!
Rail Community
