The question I think is very simple....
Imagine I have a standard naming convention for my assemblies elements
Sometimes I want to show some feature lines and sometimes other.
Can I define a "style" for this ?
Thanks.
Civil 3D (2013) how much you have to improve....
Solved by Jay_B. Go to Solution.
@Anonymous wrote:The question I think is very simple....
Thanks.
I'm not sure if your referring to Corridor Feature Lines or Feature Lines? Either way the the same styles are used.
With Corridor Feature Lines the display is controlled by "Code Set Styles" and these can apply a Feature Line Style for display.
Feature Line Styles can be found here:
Settings Tab of Toolspace>General>Multipurpose Styles>Feature Line Styles
Yes I'm asking about corridor styles.
Ok, I have found the way. Thanks again ,
