Civil 3D Forum
Any tool to provide a fast visibility toggle for alignments, corridors?
18 REPLIES 18
Message 1 of 19
tonnot
433 Views, 18 Replies
Often, screen are full of information.... surface, aligments, corridors, widenings....
I'd like a tool to have a fast way to view/hide information related to my alignments and corridors.
In example.
Do you know any "pay" tool ? Would you purchase if exists?
Civil 3D (2013) how much you have to improve....
18 REPLIES 18
Message 2 of 19
nicolas.menu
in reply to: tonnot
Just a thought,
...select object, right click >Isolate objects
Would that be enough ?
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Nicolas Menu
Product Support Specialist
Autodesk, Inc.
Message 3 of 19
Lisa_Pohlmeyer
in reply to: tonnot
What type of information?  I use the Quick Properties tool.  What would you want to hide?
Lisa Pohlmeyer
Civil 3D User
Website | Facebook | Twitter
Message 4 of 19
tonnot
in reply to: nicolas.menu
Isolate works fine but it works only with two behaviours: view this / hide that  >>> end hide that.
(maybe I'd want to add to view 'group' another element)
What I'd want is to have a global viewer for my project,
- show - hide surfaces
- show all aligments, hide all, show only an group, etc....
- And something similar with profiles, corridors, etc
Thanks...
Message 5 of 19
tonnot
in reply to: Lisa_Pohlmeyer
Lisa :
Mmmm ? How do you use that ? To view / hide ?
Th.
Message 6 of 19
Lisa_Pohlmeyer
in reply to: tonnot
I don't hide. That's why I was asking what you wanted to hide. I read your previous reply, and I understand a little further what you're looking for. I haven't searched for such a tool as I wouldn't find it useful for my workflow.
Lisa Pohlmeyer
Civil 3D User
Message 7 of 19
DaveM
In the prospector it you go to the top of a Category, Surfaces for example, you can highlight all the surfaces at one and change there styles at once. If you have a Do not display style, that can turn them all off relativity easy.
The key as shown below is to select the surfaces you wish to change styles, the right click the header of the column that you wish to edit, in this case style, all selected surface will inherit selected style.6-19-2013 2-03-46 PM.png
Dave
Civil 3D 2013
HP Z400 Workstation
6GB of RAM
296GB HDD
ATI FirePro V5700(FireGL)
Win 7 Home Professional
Please use Kudos Where Deserved
Message 8 of 19
tonnot
in reply to: DaveM
MMM It is a defficient solution. I already knew this.
I'm affraid at the moment to work with a complex project.... (this are going to be a chaos.....)
Thanks.
Message 9 of 19
Jay_B
in reply to: tonnot
Splitting up Civil 3d source drawings into various Xref overlays will also help in controlling the display of various civil 3d objects by unloading and loading the xref's.
Proper drawing setup and styles that have layering flexibility also aid in controlling the display of various objects.
Bottom line is it's done by object isolation, layering, xref's or within the styles ie: _no display style as has been mentioned.
Once a workflow has been adopted it becomes a lot easier to manage the display of objects in Civil 3d but at first it is very confusing. For me, depending on what it is I'm doing, all of these methods get used .
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Message 10 of 19
ericcollins6932
in reply to: tonnot
I'd use layer states.
Save your layer state with everything you possibly want on.
Freeze layers and save the layer state at each point you like your views until you get down to the minimum view you want.
Eric Collins, P.Tech.(Eng.)
Win 10
Intel i7 9700 @ 3 GHz
16 GB RAM
Civil 3D 2019
Message 11 of 19
sboon
in reply to: ericcollins6932
Our template has the Object Layer defaults set up so that each alignment, profile, surface, corridor etc. is created on its own layer with the object name as the suffix.  That way I can use the layer isolate or layer freeze commands to control the visibility of each one.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve
Expert Elite Alumnus
Message 12 of 19
tonnot
in reply to: sboon
At last !!!
This is the way.
Can you explain how do you do it ?
I have explore it just a little and I suspect that you must to do it manually ?
Regardless of all, it is the most interesting approach !
Message 13 of 19
DaveM
in reply to: tonnot
Dave
Civil 3D 2013
HP Z400 Workstation
6GB of RAM
296GB HDD
Message 14 of 19
sboon
in reply to: DaveM
Dave has the right idea.  Here is my list, sorted to group together all of the objects that use suffixes.  One difference to note - I don't put labels on separate layers.  I find that it's not necessary, since the labels will not display for objects that are frozen.
Steve
Steve
Message 15 of 19
jmayo-EE
That's what I do to. I typically have layer states and views saved for each shet in a plan set. I may also have them for details, profiles and sections. I like this because I can isolate quickly whith the layer state dropdown in the quick access bar and scales are saved with the views.
John Mayo
Message 16 of 19
jmayo-EE
in reply to: sboon
Leave the choice to the OP.
If you want these layers to exist in every file without the ability to delete empty layers use an object layer name that is not 0.
If you want layers created only when objects are created and the ability to delete empty layers use 0 for the object layer.
John Mayo
Message 17 of 19
jmayo-EE
in reply to: jmayo-EE
John Mayo
Message 18 of 19
DaveM
Does it Keep the "0" in the name?
Dave
Civil 3D 2013
HP Z400 Workstation
6GB of RAM
296GB HDD
Message 19 of 19
jmayo-EE
in reply to: DaveM
Yes it does. If I create a surface named EG a layer is created named SRF-EG-0. If I place labels on the surface another layer is created named SRF-EG-LBL-0.
John Mayo
Rail Community
