In Ontario Canada, the provincial standard is 2% top crossfall & 3% subbase crossfall. Has AutoDesk ever released subassemblies that allow different grades? Is there a country pack that has them?
Solved by sboon. Go to Solution.
I usually use ShoulderExtendAll for this. It allows you to specify a different slope for the subgrade
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve, do you use the shoulder subassembly for the lanes themselves? I can see how that would work.
Yes that's what I do. It's a bit of a hassle because the sub has a link with a Top code on the outside edge. You have to use some generic links in the assembly to get the surface working properly. Here's some pics from a project several years ago.
Came across a problem with this as I was trying to attach a profile to the outer edge of a rural shoulder. You can't. I don't know why AutoDESK has to make simple things so hard.
