Has anyone ran into this?
I have several jobs now that the LOCKED viewports keep resetting to 0,0 in my layout tabs. The viewports will keep it's scale but just pan back to 0,0.
I have read somewhere that viewports can be corrupted very easily...
Is there anyway to keep this from happening? or a way to fix the problem once it happens? I currently just reset up the viewport...
i lose time and money every time this happens... I just would like to figure this out before this completely gets out of hand...
Elijah Ransom
I have had this issue myself, but could not find a definite cause.
I think that an audit and purge stopped this happening on the particular drawing that had this issue.
Does this only happen in one drawing? Does it only happen on one layout tab? I personally have never run across this, but if only one drawing and one layout tab, try deleting the tab and recreating it.
I've had this issue happen a couple of times. I posted about it in the regular Autocad group. It apparently happens a lot, but Autodesk seems to be ignoring it. I haven't been able to pinpoint when it happens or what causes it. The last drawing I saw this happen in was an older drawing that hadn't been opened in over a year.
I have this issue now in several drawings that I open nearly every day... actually one of the files reset about 25 viewports 3 times now in the last 3 months...
The drawing does contain xrefs; could a setting inside one of the drawings cause this issue? I did purge and audit the drawing file, but the problem was still there...
This is happening to several AutoCAD users in my office... My UCS FOLLOW is set to 0... the weird this is... Not every viewport resets in the drawing... I mean the layout that the file opens with is never affected by this, I could move to another layout, save and then reopen the file, but the layout that was fine before is now reset in the drawing file... And it is always the largest viewport in the layout, the smaller viewports in the layout never reset as well...
I am really not sure on how to fix this... I would post up the drawing, but I have already reset up the viewports hoping that this would be the last time that this happens...
So this happen 3 separate times in the last 3 months? Do you recall any "events" that may have occurred on your server or your machine(s) around the time this happened?
This happened 4 to 5 times in the last 3 months... 3 times with just one drawing... I do not remember anything in particular... I did however have to purge the nested DGN linestyles out of the file... Maybe runnning the app makes the drawings unstable?
What tool did you use to purge DGN linestyles?
I used the ATK-Purge application , That could possibly cause the drawing to become unstable... I audit and purge the drawing after running the application...
Not sure if it did or not, as I am not sure what that application removes from the drawing. I would be cautious if this same issue happens in all drawings you ran that app in.
I had this happen a lot with viewports where I had used the Map Tool that puts a north arrow in that aligns with the viewport. I had to stop using it. Haven't had issues since. *knock on wood*
I have had similar issues with my viewports in different drawings and have found three different commonalities. One, there are mapped objects in each drawing; two, there are data shortcuts in each drawing and finally, what I believe was the biggest issue, having multiple, more than three, drawings open at one time.
I hope this helps.
