Ok, Ill try to explain this as simply as possible through an example. For instance I want to create a new surface, I right click surfaces in the prospector and selecte create new. The pop up window appears asking how to name the point cloud.....clicking next takes you to the next menu, BUT....its grayed out. It will not become active until I grab the titlebar of the popup window and move it accross the screen. It also is not just the next button, every option in the pop-up window wether it be a drop down box, text field, radio button, etc. will not allow me to move onto the next option field until I move the pop-up box. Its really annoying. Has anyone else had this problem and is there a fix?
