New Member
spgwins
Message 1 of 5 (556 Views)
annotating lines in inches
556 Views, 4 Replies
05-16-2012 11:53 AM
I have a drawing that was created in engineering units, the architect needs buildings dimensioned to the nearest 1/2". I copied the building footprint, scaled it up a factor of twelve and changed the units to inches, the dimension styles to inches, but i cannot get the dimension tool to show inches (only tenths of foot. Is there an easy solution I'm overlooking?
jmayo
Message 2 of 5 (536 Views)
Re: annotating lines in inches
05-16-2012 02:15 PM in reply to: spgwins
Another method is to leave your file eng units and make a dimension style that scales the measurement to inches. Simply add a scale factor of 12 to the Primary Units tab of any dimension style. Save the dimstyle to your template and this can be a bit less work.
If you must scale it for the arch then open the file you saved with the scaled bld. Confirm the scale operation with the distance command. If this is off check the Units command. Since you scaled the building up you need Archtectural set. Make sure the dimension style's Unit Format is set to Architectural and the scale factor is 1.
John Mayo, PE
IDSP 2014
Win 7 64, Xeon ES165@3.2Ghz,
64 GB RAM, Quadro K4000 (x2)
Joe-Bouza
Message 3 of 5 (530 Views)
05-16-2012 02:37 PM in reply to: jmayo
I ditto that
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
jmayo
Message 4 of 5 (527 Views)
05-16-2012 02:42 PM in reply to: Joe-Bouza
Of course if you opened Acad with an arch dwg and xref in your engineering dwg AutoCAD can also automatically scale the file if insunits and it's associated commands are all set properly. Just one more way to mess things up. :smileyhappy:
John Mayo, PE
IDSP 2014
Sinc
Message 5 of 5 (498 Views)
05-20-2012 08:17 PM in reply to: jmayo
In case John's response was a bit vague, here's an image:
In general, you DO NOT want to work in Architectural units in C3D (in other words, leave all your drawing settings set to Feet/Meters, and DO NOT change the UNITS).  Instead, use the trick above to create a Dimstyle that labels what you want.
Of course, this only works with Dimstyles, and we're still missing a way to do something similar with C3D Styles (such as labeling a volume surface in fractions of an inch), but C3D is still a work-in-progress with much left to do...
Sinc
