I have a profile with multiple surfaces, when I update a surface the line in the profile that represents the surface updates. However the dynamic text or hatch that is associated with the surface does not
The dynamic text or hatch (which is dynamic to the surface) act’s like it’s still labeling the old surface line
I can edit the profile properties by changing the surface to static then back to dynamic, this will correct the hatch however all the text labels will be gone
This problem creates a huge amount of work
To fix the problem I delete the dynamic text and manual add new text that is dynamic to the profile only
Which means after any updates the text needs to be moved manual
I am sure this is not the way this software is suppose to work
Can you post a screenshot? Also, what kind of information are you displaying and what objects/process are you using to display the dynamic portion of the text?
