Civil 3D Forum
angular input
5 REPLIES 5
558 Views, 5 Replies
angular input
we have a crew that still gets field notes in the old fashion way - when we enter the side shot information by creating points manually we use the same format as drawing a line with bearing (ex: 32.7896 as angle then distance) - when we check the sideshot angle it appears to be taking the angle as a decimal degree instead of degrees minutes and seconds - is there a way we can correct this?
thank you very much
5 REPLIES 5
Jeff_M
Toolspace, Settings, rt.click drawing name, Edit Drawing Settings, Ambient Tab, scroll down to Angle, change the format here.
Jay_B
UNITS command>Angle Type>Surveyors Units.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
in reply to: Jeff_M
well you are my new best friend - thank you so very much
wfberry
in reply to: Jay_B
Jay:
I don't think he should do that.
Bill
Jay_B
in reply to: wfberry
Bill,
I misunderstood the OP's intent in this case but I don't believe there's any issue with changing the setting
as mentioned.
Surveyor Units are displayed in Properties Palette, when using vanilla Acad List command etc. for a
line segment instead of in Decimal Degrees.
Maybe I've got it all wrong but my understanding of the UNITS command and it's affect on Civil 3D's Units
(Ambient Settings) is like this Being Civil Post describes.
C3D 2018.1
C3D 2016 SP4
Rail Community
