Civil 3D Forum
An easy corridor question~~~
1 REPLY 1
STUARTDAVIS
295 Views, 1 Reply
hello,
If someone could help me that would be great!
1)Changing location of corridor baselines on the list under parameters, is it possible? For some reason my materials won't compute for a baseline that I created out of station order! I imagaine its as simple as 1, 2, 3! However I have 2, 3, 1, and I can't get them in right order. materials are computed fine until it reaches the out of order baseline.
The only solution I can think of is to not do a materials report, but rather compute quantities by comparing surfaces at the pave, base and subase links. I don't like that idea, too much work.
Thanks in advance!
1 REPLY 1
I don't think there is a way to reorder the baselines. If the materials aren't working you could create a new sample line group for the region were it's not being calculated and then compute the materials for the new sample line group. Then combine the two sample line materials in Excel.
Rail Community
