trynders
Message 1 of 9 (476 Views)
Alley Corridor
476 Views, 8 Replies
12-26-2012 09:23 AM
Hi All,
What's the best way to model an alley with a 90 degree angle (turn).  Do I treat it as an intersection with a zero radius?  My typ section is 15 feet width with a 4% slope down to the center of pavement.  "V" bottom.  Not sure how to get it to model the outside corner and also eliminate the inside overlay.  Thanks,
tcorey
Message 2 of 9 (470 Views)
Re: Alley Corridor
12-26-2012 10:19 AM in reply to: trynders
Tim Corey, Owner
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
tcorey
Message 3 of 9 (461 Views)
Re: Alley Corridor
12-26-2012 10:38 AM in reply to: trynders
I don't know if I would necessarily use the Intersection tools, but I would make a multi-baseline corridor to handle this.
If you're not familiar the feature, a Corridor can have multiple alignments defined as Baselines. Each will have its own design profile and assembly.
See the attached simple corridor with 90 degree corner.
Tim Corey, Owner
Redding, CA
Valued Mentor
fcernst
Message 4 of 9 (417 Views)
Re: Alley Corridor
12-26-2012 06:58 PM in reply to: tcorey
I don't see the advantage of using a multi-baseline Corridor?
One baseline, and you would not have to monitor and update the common PVI across two profiles.
Fred Ernst, PE
C3D 2015 SP2
Ernst Engineering
www.ernstengineering.com
trynders
Message 5 of 9 (400 Views)
Re: Alley Corridor
12-27-2012 05:47 AM in reply to: trynders
Thanks tcorey,
I was going to take a look see but im using 2012 and apparently you attached a newer version.  Sad day.
Distinguished Mentor
andrewpuller3811
Message 6 of 9 (362 Views)
Re: Alley Corridor
12-29-2012 03:44 AM in reply to: trynders
Here is a blog post of mine covering this
http://andrewscivil3dstuff.blogspot.com.au/2011/06/create-corridor-with-90-degree-bend.html
and a similar topic with sample drawing is here
http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Intersection-Design-90-degree-turn/m-p/3012576
If this fixed your issue, click on "Accept as Solution"
Andrew Puller
Maitland, NSW, Australia
Windows 7 Enterprise 64bit
Intel core i7 2600 @ 3.40 GHz with 16GB Ram
Civil 3d 2013 64bit
Valued Mentor
fcernst
Message 7 of 9 (345 Views)
Re: Alley Corridor
12-29-2012 03:50 PM in reply to: andrewpuller3811
Good show mate!  Let's kick it up a notch..   A mitered interior corner cleanup for the intersection:
One corridor, one assembly, one profile...fully dynamic.
Fred Ernst, PE
C3D 2015 SP2
Ernst Engineering
BrianHailey
Message 8 of 9 (318 Views)
Re: Alley Corridor
12-30-2012 05:00 PM in reply to: fcernst
Care to share the drawing Fred? I would love to see your approach to this. I think I know how you did it but I'm not positive.
Brian Hailey
CAD-1.com
My Blog
tcorey
Message 9 of 9 (297 Views)
Re: Alley Corridor
12-31-2012 09:01 AM in reply to: fcernst
I like Fred's result as he is able to include cross secitons in the mitered area. Do you care to expound?
Tim Corey, Owner
Redding, CA
