In Civil 3D 2015, when I'm switching my Workspace to Planning and Analysis, all the Map related icons images are missing (showing me a question marks).
How can I fix this?
Thank you
Thank you for your reply.
I found a solution:
1. In the Civil 3D command line, type OPTIONS and hit Enter.
2. On the Files tab, expand the Support File Search Path.
3. Add these paths (not sure if I need all 3 but it work...):
C:\program files\autodesk\autocad 2015\map
C:\program files\autodesk\autocad 2015\map\en-us\userdatacache\support
C:\program files\autodesk\autocad 2015\support
4. Exit and relaunch AutoCAD Civil 3D 2015.
Good find. I forgot about that one, even though I had it documented here (pretty sure this is the same problem, 9th one from the bottom)
