I ended my session yesterday, plotted my first layout, everything looks perfect. I started up today and everything is gray. Drawing layer colors are correct. Everything looks ok in the properties pane when I select anything. Print preview shows everything black. Never had this happen before. Solution?
Solved by miker. Go to Solution.
Occurring in model or paper space or both??
Hi - Can you explain how you solved this issue in more detail? I'm having the same problem- layers show up as gray in both model and paper view but colors are correct in the properties pane.
Thanks!
Thank you for this post!! I had the same problem and the Display Plot Styles did not help.
I dont know what the solution was for the original poster, but
If you have been playing with maps and data connect, this may help.
Type in command line: mapwspace
Task Pane On/Off <on>: hit enter to accept on
a task pane bar will load, you need to expand it by clicking on it (looks similar to prospector or panaroma bar).
Click on Display Manager tab, make sure Default is unchecked.
Solution also found here.....
Hope this helps!
Just thought I'd let you know your solution has just helped a colleague of mine retain his sanity after battling with the problem for hours!
lorrie...you just saved my life. I was about to end it all by running into traffic. I have spent the last 90 minutes or so pulling my hair out trying to figure out why all of my linework has turned gray.
Thank you so much.
