Active Member
miker
Message 1 of 12 (1,221 Views)
All my drawing colors display as gray
1221 Views, 11 Replies
09-05-2012 11:24 AM
I ended my session yesterday, plotted my first layout, everything looks perfect.  I started up today and everything is gray.  Drawing layer colors are correct.  Everything looks ok in the properties pane when I select anything.  Print preview shows everything black.  Never had this happen before.  Solution?
Mike R.
Change layer setting.  Seems to have worked.
Just had this problem in AutoCAD Map 3D 2014 - solution still works - THANKS!
Jeff_M
Message 2 of 12 (1,219 Views)
Re: All my drawing colors display as gray
09-05-2012 11:34 AM in reply to: miker
Is "Display Plot Styles" checked in the Page Setup? If so, uncheck it.
Active Member
miker
Message 3 of 12 (1,207 Views)
09-05-2012 12:03 PM in reply to: Jeff_M
Box is not checked.
Mike R.
neilyj
Message 4 of 12 (1,198 Views)
09-05-2012 12:20 PM in reply to: miker
Occurring in model or paper space or both??
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 240Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
Active Member
miker
Message 5 of 12 (1,187 Views)
09-05-2012 01:06 PM in reply to: neilyj
Both
Mike R.
Active Member
miker
Message 6 of 12 (1,140 Views)
09-07-2012 12:29 PM in reply to: miker
Mike R.
Active Member
miker
Message 7 of 12 (1,089 Views)
09-12-2012 04:05 AM in reply to: miker
Not checked Michael Robertson CAD and Lab Operations Manager Blackburn Consulting :blocked::mailto:brendaf> Office: (916) 375-8706 Cell: (916) 717-9909 Fax: (916) 375-8709 e-mail: miker@blackburnconsulting.com 2491 Boatman Avenue, West Sacramento, CA 95691 :http:smileyembarrassed::http:smileyembarrassed: www.blackburnconsulting.com:blocked::mailto:brendaf>
Mike R.
Active Member
miker
Message 8 of 12 (1,089 Views)
Both Michael Robertson CAD and Lab Operations Manager Blackburn Consulting :blocked::mailto:brendaf> Office: (916) 375-8706 Cell: (916) 717-9909 Fax: (916) 375-8709 e-mail: miker@blackburnconsulting.com 2491 Boatman Avenue, West Sacramento, CA 95691 :http:smileyembarrassed::http:smileyembarrassed: www.blackburnconsulting.com:blocked::mailto:brendaf>
Mike R.
New Member
tshafer
Message 9 of 12 (976 Views)
01-07-2013 02:04 PM in reply to: miker
Hi - Can you explain how you solved this issue in more detail? I'm having the same problem- layers show up as gray in both model and paper view but colors are correct in the properties pane.
Thanks!
lorrie.bundy
Message 10 of 12 (772 Views)
08-22-2013 02:49 PM in reply to: miker
Thank you for this post!! I had the same problem and the Display Plot Styles did not help.
I dont know what the solution was for the original poster, but
If you have been playing with maps and data connect, this may help.
Type in command line: mapwspace
Task Pane On/Off <on>:    hit enter to accept on
a task pane bar will load, you need to expand it by clicking on it (looks similar to prospector or panaroma bar).
Click on Display Manager tab, make sure Default is unchecked.
Solution also found here.....
http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Lines-with-different-colours-look-the-same/td-p/42934...
Hope this helps!
