Civil 3D Forum
Alignments and Profiles lost during publish
2 REPLIES 2
rdlongbow
218 Views, 2 Replies
I have an interesting publish problem: I have two alignments with profiles, that when I publish either from the layouts, or from SSM, don't show up in the pdf. This includes the labels. If I do a plot of the individual sheets, they show up fine. There are other alignments using the same styles that publish just fine.
I had to repair the shortcuts to these two alignments. Not sure if that would have anything to do with it. Can't see how, since they plot fine. What's maddening is that I published a set of plans before repairing the shortcuts, and they came out fine.
I restored a previous version which required the shortcut repair, and it does the same thing.
Any ideas on this one?
2 REPLIES 2
rdlongbow
in reply to: rdlongbow
It appears that my sudden publishing problems came about due to Background Publishing being enabled. Disabling this clears up the problem.
gccdaemon
There is also a problem with opening the generated PDF's in older versions of Adobe. You have to check and make sure you have AT LEAST adobe reader or acrobat x.
Andrew Ingram
Civil 3D x64 2019
Win 10 x64 Pro
Intel Xeon E5-1620
32 GB Ram
Rail Community
