i found a way to get a report of my cogo points relative to an alignment i.e. station offset. problem is, i have thousands of points in my drawing. is there a way to get only a few, or a group of points to show up on the report instead of ALL of them?
"i found a way to get a report of my cogo points relative to an alignment i.e. station offset"
If your referring to the Create Reports - Station Offset to Points Report method, I'm not seeing any way other than select all within this command.
Thinking outside the box a , you could create a "Point Group" containing only the points you'd like to create the Sta/Off report for and from "Export Points" dialog box choose "Limit to Points in Point Group" and export to an ascii file.
Create a New dwg_import points_dref alignment into dwg_run the report_print report.
Hope this helps.
