I was trying to find a way to not have the last ending Station Label show up on my centerline is there a override or way to tell it to just label to the last 100 or 50 foot station?
Solved by bham4ever. Go to Solution.
You can create an expression to do that. Something like:
if(STATION VALUE = trunc(STATION VALUE),0.1/12,0)
and use that for the height of the text.
p.s. I didn't actually look at the correct syntax for the expression so you won't be able to copy/paste this. Just create it yourself.
OK..I'm a little stupid today..all I had to do was to go to my Label Style and uncheck the ending station and change it to a Station just before the end Station.
Problem solved....!
The only thing to watch out for with that is it will remove any minor station ticks also. For example if you line ends at +75 and you minors are at +50. If you tell it to move back to a major station you will lose the minor station.
You always have the option of holding down the "Ctrl" key while selecting the label and delete it (only).
Bill
Windows 7 x 64 Professional
Nvidia GeForce 9800 & 8500
12 GB Ram
i7 965 @ 3.20 GHz
Corsair Force 240 GB SSD
Infrastructure Suite 2014
