Civil 3D Forum
Alignment stationing
1 REPLY 1
diegoal
385 Views, 1 Reply
Dear all,
Here in Brazil we use station format with increments of 20 meters, not 100 meters that I believe that is usual in USA.
I was able to change some alignment and profile stations formats but some formats remains and I wasn't able to find where I can change them... in the picture screen.jpg I show some changed stations in yellow and not changed in red...
I tried to change this main configuration at settings > my drawing > edit drawing settings > station but I only can set the format type I wanted: decimal to station index format, i.e. (screen2.jpg)... but where can I set the 20.0m distance increment?? It remais with 100.00m.
If I solve that it will help me a lot reducing CAD postprocessing time.
Thanks a lot,
Diego Álvares
Civil Engineer @ Trento Engenharia Ltda.
www.trentoengenharia.com.br
Autocad Civil 3D 2010 to 2017 - Infrastructure Design Suite
Windows 7 64 i7 4770 @3.40GHz 8GB Ram GeForce GTX 760
Please use the Accept as Solution or Kudo buttons when appropriate
1 REPLY 1
SethHall
in reply to: diegoal
This should be available in the Brazilian Country Kit. Just open and use the DER-SP template that came in the country kit and this should allow you to use the 20m stationing.
Seth Hall
Product Owner
Model Builder
Rail Community
