Hi, I have the same accuracy problem. I did all the steps you indicated and the drawing on the screen worked, but when I use the command below to generate a report:
<td> <xsl: value-of select = "landUtils: FormatStation (string (@staBack), string ($ Alignment.Station.Display), string ($ Alignment.Station.precision), string ($ Alignment.Station.rounding )) "/> </td>
The report keeps coming to 3 decimal places. Would you have any ideas
