Is it possible to add a prefix to an alignment station label (ex. A 100+00.00 or B 100+00.00) in Civil 3D 2010 or later?
Solved by Joe-Bouza. Go to Solution.
put the prefix in the alignment description and add to the style
Your Name
Your Name
Mr. Bouza,
I appreciate your reply to my question. However, I could use a little more clarification. I am trying to change existing alignment labels and don't understand where the alignment description field is your referring to or the style I should add it to.
Thank you for your help
Please call me Joe I hope these picture help
Your Name
Your Name
Hello Joe,
Thank you for the screen shots, they made it very easy to do and understand. I appreciate the extra effort.
Mike
Hi Michael
HTH. Please select "accept solution" so other readers may be aware of your solution
Your Name
Your Name
