Valued Contributor
darrell.wilmore
Message 1 of 3 (141 Views)
Alignment station justification
141 Views, 2 Replies
12-10-2013 08:07 AM
I have a novice problem that one of you older pros have a solution. There should be a simple solution but I can't seem to find it.
How do you change the station justification on an alignment? My stations are centered on the alignment and I want to move them perpendicular to the centerline and offset them to the left of the alignment. I pick the stations and get the label group ribbon but I can't seem to find the justification commands on the ribbon or under the properties dialog box. I do have them perpendicular to the alignment. I found that command.
Not sure exactly what your after but there is an X / Y offset value that may help to offset/justify the text in relation to the alignment & tic marks.
These are found on the "Layout Tab" in your alignment label style.
If it's the actual text you wish to justify then go to same Layout Tab>Text>Contents>Radio button>Text Component Editor>Format Tab>
highlight contents in view on right and choose the Right Arrow to push the new info to the viewer>OK
Jay_B
Message 2 of 3 (135 Views)
Re: Alignment station justification
12-10-2013 08:25 AM in reply to: darrell.wilmore
Jay
C3D 2014 SP2
Win 7 Professional 64 Bit
Valued Contributor
darrell.wilmore
Message 3 of 3 (128 Views)
12-10-2013 08:44 AM in reply to: Jay_B
Thank you for your time.
I found it.
