My dragged state leader does not display properly. The attachment runs through my first line of text. Any suggestions out there that may correct this problem? My display is set to "As Composed" I do not want the stacked text setting.
Thank you. I have attached a picture that shows the issue I am having.
Send an image of what your Layout Settings are set to.
I have attached all the label style settings. When you wrote send the layout settings I was thinkingh you mean the label style setings.
I was meaning how is the text to look without being stacked. It seems to me that you have the text manally stacked in the contents if you have the dragged state set to AS COMPOSED. But in doing this it will override the leader attachment location.
Yes I did stack my text manually in the contents field. I did not know using "As Composed" would override the leader settings. Guess I am going to have to live with the display setting set to "Stack".
Thanks for your help.
Yes it looks like I am going to have to go with the Stack text setting. I can live with it and it beats creating leaders manually, too much work I have a large number of Sta & Offset labels.
How is the text looking when setting it to stacked?
If it's modifying it too much, Copy the style you have and have the text attachment set to middle right instead of middle left. So you'll have two styles for either location.
Yes I thought of creating two styles as well. I am keeping my labels left justified, I have enough room in the drawing and I like the uniform and neat look being displayed. But, I am saving the right justified label in my DWT for future use.
Thanks again
In the settings file, under Leader Attachment, it is set to "Middle of Top Line"
Look and see if there as a Left or Right justification to attach it too.
I haven't done any testting on that but that looks like that could be where you need it to go. If so, changing it once in the style will change all of them.
Surveyor Lee
