AutoCAD Civil 3D General Discussion
Distinguished Contributor
1 Kudo
Post 11 of 17
Re: Alignment station -0+00
09-09-2013 09:24 AM in reply to: doni49
Here's a file with the problem alignment - Braddons. I included the alignments before and after it.
*Expert Elite*
172 Kudos
Post 12 of 17
09-09-2013 11:01 AM in reply to: charles.neely
I can't open it -- I'm on C3D 2012 and got a message that it was saved in a newer version -- sorry.  Hopefully someone else can assist you.
Don Ireland
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given. Such messages will be deleted unread & without a reply.
Forum links:
AutoCAD 2013/2014/2015
AutoCAD 2010/2011/2012
AutoLISP, VB and other AutoCAD customization
Civil 3D General
Civil 3d Customization
Other Helpful links:
My File is too large to post or I can't post it due to privacy issues!
*Expert Elite*
911 Kudos
Post 13 of 17
09-09-2013 11:07 AM in reply to: charles.neely
I've had this issue before. I think it also involved an alignment which started with a curve. If you don't plan to have any station labels that are negative, change the label style to drop the sign.
Jeff_M, also a frequent Swamper
*Expert Elite*
418 Kudos
Post 14 of 17
09-09-2013 09:23 PM in reply to: Jeff_M
I've also run into this problem on occasion.  Seems to be an issue somehow with calculating the location of the reference point relative to end of the arc that starts the alignment.  I found that setting the reference station to something just barely positive seems to work.
New Member
0 Kudos
Post 15 of 17
09-08-2014 02:15 PM in reply to: charles.neely
I was having the same problem. Here is a general solution:
Go to the TOOLSPACE tab and go to SETTINGS
Find youe station label by opening the ALIGNMENT---LABELSTYLES---LABELSETS---STATION---MAJORSTATION
Right click on the type of style and select EDIT (this will open your "Label Style Composer")
Click on the LAYOUT tab and find the CONTENTS property and select the corresponding prompt box in the "Values" column'
This will open another box "Text Component Editor". Select STATIONVALUE under the "Property" dropdown
Next, find the "Sign" row and select the corresponding dropdown in the "Values" column
Scroll down and select DROPSIGN
Finally CLICK THE APPLY ARROW at top of the "Text Component Editor" box.
Click OK and APPLY and the major station text format should be edited.
*Expert Elite*
326 Kudos
Post 16 of 17
09-08-2014 03:29 PM in reply to: charles.neely
Alignment properties>>> station control, set it to 0
it probably got gripped and got squirly
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
20 Kudos
Post 17 of 17
09-09-2014 10:42 AM in reply to: Joe-Bouza
Delete the first curve section.
Redraw the curve, but with a tangent piece at athe beginning.
Delete the tangent piece.
Post to the Community
New Post
