<ACADuser> wrote in messageCreate
href="news:6198576@discussion.autodesk.com">news:6198576@discussion.autodesk.com...
an alignment using whatever methods are available. Where in heck in the
toolbars do you set the reference point/station ? After creating the aligment
I have to go to the alignment properties > station control, and set the
reference point/station. Why can't i set it during creation of the aligment ?
Having to change it after the fact would'nt be so bad if it were not for a few
"irritations"; 1) TWICE, you have to click ok to the warning (once for the
station value and once for the xy location. 2) Every time i edit the alignment
(add a pvi...) the reference point changes (the x/y location). Whats the deal
with that ??? What am I doing wrong ? Any good workarounds
I am having a similar problem. I need to stretch an existing alignment to the south, but I don't want all of the stationing to change. I just want to stretch the alignment, but pin the existing stationing so that I get the starting location to change as I move it. I know I knew how to do this, but I have been away from C3D for a couple of years. Is it as simple as C3D can't and I need to figure out the starting location station so that everything lines back up to the north?
Brad
C3D 2011 64 Bit SP 1
Vista Business 64
3.0 Core 2 Quad, 8 GB RAM...
Alignment Properties, Station Control Tab, set the reference point somewhere else than the beginning of the alignment, putting in the correct station value for the selected reference point.
Christopher
Thank you. I actually figured it out myself, but did not get back here to write a "nevermind" post.
Brad
If you create another PI on the reference point (not ideal I know), the station will not change whenever you grip edit the others ends
