Civil 3D Forum
Alignment Profile geometry keeps moving
9 REPLIES 9
Message 1 of 10
WyldeParnelle
920 Views, 9 Replies
Anyone ever experience your profile geometry randomly moving over by no specific number. Often I will open my drawing and several of my profiles are all messed up because the geometry moved. I have resorted to drawing circles at all the points so that if it moves I can reposition it. Super pain in the butt - Using Civil 3D 2012.
9 REPLIES 9
Message 2 of 10
Jeff_M
in reply to: WyldeParnelle
I have never had any geometry move on it's own. Accidental grip edits, perhaps?
Jeff_M, also a frequent Swamper
Message 3 of 10
WyldeParnelle
in reply to: Jeff_M
Nope...I will close my drawing and go back to it and several profiles will have moved. It has happened to a coworker as well and neither of us have been able to figure out why and how to stop it.
Message 4 of 10
WyldeParnelle
in reply to: Jeff_M
here is an example...I just saved my drawing, closed Civil 3d and re-opened...look at the images a.jpg is where the profile is supposed to be and b.jpg is where it ends up.
Message 5 of 10
model space, or paper space view?
drefs?
If I have a drawing with the topo surface with a scale of 1:1000, and a separate drawing with the plan and profile at a scale of 1:500, I may see a shift. Generally, synchronize each d-ref will "fix" it. Sometimes an audit will make it work.
If you have a ucs other than world, or base point other than 0,0 it could cause issues as well.
Make sure layers are off, not frozen. Especially with drefs.
Message 6 of 10
Do you have padding on your grid?
Message 7 of 10
WyldeParnelle
model space, or paper space view? - Model
drefs? - Yes 2
If I have a drawing with the topo surface with a scale of 1:1000, and a separate drawing with the plan and profile at a scale of 1:500, I may see a shift. Generally, synchronize each d-ref will "fix" it. Sometimes an audit will make it work. - Will try Audit - 172 errors (Yikes)..also did recover...now only one moved. Will try it again.
If you have a ucs other than world, or base point other than 0,0 it could cause issues as well. - UCS = World
Padding - ?
Message 8 of 10
Open my drawing this morning and ALL of them moved again. Good thing I put little circles to place them back where they belong. Driving my bonkers!
Message 9 of 10
Edit the profile geometry with the profile layout tools.  Verify that the grade break and PVI station values are correct.
David Zavislan, P.E. | Wood Rodgers, Inc.
Message 10 of 10
YES...thanks, that fixed it. I locked all the PVI points and no longer move.
Rail Community
