Hello!
I'm having problem with following alignment:
R=-750.00m
start point x=5466927.47458, y=5016583.65233
endpoint x=5467320.93928, y=5016310.25691
followed by two transitions L=115.00m, and L=115.00m
and reverse curve R=700.00m (end point x=5467974.57928, y=5015894.49926)
First curve is created with option Fixed Curve (Two points and radius) and
second with option Floating Reverse Curve with Spirals (From curve, radius,
through point).
When I try to do this with this coordinates, I don't get any result. On the
other hand, when I use following coordinates:
R=-750.00m
start point x=6927.47458, y=6583.65233
endpoint x=7320.93928, y=6310.25691
and reverse curve R=700.00m (end point x=7974.57928, y=5894.49926),
everything works fine.
When I open Civil 3d (it opens with acad.dwt template) everything works fine
with both sets of coordinates (both metric and imperial units).
When I open new document with same template (acad.dwt) I have the same
problem again.
I'm using _AutoCAD Civil 3D (Metric) NCS Extended.dwt template.
I tried with limits command (switching it to off) but nothing changed.
Thanks for help in advance!
