I am trying to export an Alignment PI Station Report. I've set all the settings I can find to round coordinates to 4 decimal places, Distance to 2 decimal places, and Direction to the nearest second (DMS). When I execute the PI Station Report, the Distance is 3 decimal places and the Direction is to the nearest 100th of a second. Anyone have suggestions on how to get these to the correct decimal place? I managed to change them to the correct decimal place for a Station & Curve Report, but not for the PI Station Report. Also, for the Northing/Easting coordinates, I want to remove the commas (for example, a Northing of 3,058,715.3774' should read 3058715.3774').
Thank you,
Chris
Solved by mathewkol. Go to Solution.
This needs to be done in the alignment feature settings in the settings tab. You didn't say what you tried so I'm assuming you've not tried this.
The other reports (at least the XSLT style) honor settings changes in the report settings dialog, but the PI report is a .NET report and it does not user those settings, but the ones in the settings tab.
Thank you!
I still can't figure out how to remove the commas from the coordinates, but that's not a big issue.
Thanks again,
Chris
There are just some things that you can't do in there. I'm not saying there isn't a way to do what you want exactly, but there may not.
@ccino wrote:I am trying to export an Alignment PI Station Report. I've set all the settings I can find to round coordinates to 4 decimal places, Distance to 2 decimal places, and Direction to the nearest second (DMS). When I execute the PI Station Report, the Distance is 3 decimal places and the Direction is to the nearest 100th of a second. Anyone have suggestions on how to get these to the correct decimal place? I managed to change them to the correct decimal place for a Station & Curve Report, but not for the PI Station Report. Also, for the Northing/Easting coordinates, I want to remove the commas (for example, a Northing of 3,058,715.3774' should read 3058715.3774').
Thank you,
Chris
I am trying to run a similar report. The only thing I cannot change is the format of the direction settings. Right now the report is returning an azimuth for the direction. I would like to change that to DMS and I noticed that you said you already changed that. Where do you change that setting? I am poking around in the "Edit Report Settings" box and I don't see a place to change it.
I am currently using Civil 3d 2012. Please help if you can.
alignment report gives me different pi and different coord. than the dwg.
as shown on inset. ex. pi station in cad is 1+69.93 but report says 1+88.01
please help
