I created a miscellaneous alignment and everything came out exactly how I wanted it to show. But I do not see this alignment in my prospector tab. I see the other centerline alignments, but when I click on Miscellaneous Alignments I do not see my alignment. It does not even have a plus box to expand. I have saved my drawing a couple times and still nothing.
I even changed it from miscellaneous to offset just to see if that had any relation to the issue, but it still does not come up in the prospector tab.
Any Pointers?
Solved by sboon. Go to Solution.
Is it possible that your alignment was created inside a Site?
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
