AllenJessup
Message 1 of 11 (287 Views)
Alignment Name Cap Style
287 Views, 10 Replies
10-24-2012 11:49 AM
This is strange. I wanted to label just the alignment name in a couple of places. I have an Alignment Name Label Style that does this. I now notice that it will capitalize some of the lower case P's in the curve label. Not the line label just the curve. They're applying the same style. It also changes back to lower case if I drag the label.
The style has one component and that is the Alignment Name and has Preserve Case set.
Allen
BrianHailey
Message 2 of 11 (265 Views)
Re: Alignment Name Cap Style
10-24-2012 06:44 PM in reply to: AllenJessup
That doesn't look like a capital P to me. It looks like a lower case p that has been shifted up so the bottom of it lines up with the bottom of the rest of the letters. Can you put a capital P in the label somewhere so we can see how it compares?
Brian Hailey
CAD-1.com
My Blog
AllenJessup
Message 3 of 11 (256 Views)
10-25-2012 05:47 AM in reply to: AllenJessup
Brian,
Your right. Lower case P. It's also doing it with lower case J's,G's and Q's.
This only happens on arcs. The Label style isn't very complicated. I've tried changing the anchor point and attachment and that doesn't have any affect.
Allen
jmayo
Message 4 of 11 (248 Views)
10-25-2012 06:41 AM in reply to: AllenJessup
Does it work correctly if you turn off the Curve Text option?
John Mayo, PE
IDSP 2014
Win 7 64, Xeon ES165@3.2Ghz,
64 GB RAM, Quadro K4000 (x2)
AllenJessup
Message 5 of 11 (246 Views)
10-25-2012 06:42 AM in reply to: jmayo
Yes
jmayo
Message 6 of 11 (240 Views)
10-25-2012 07:05 AM in reply to: AllenJessup
The curve text function is shifting everything to fit. I think this shifting would be less noticable with all caps. I would start a support case.
John Mayo, PE
IDSP 2014
AllenJessup
Message 7 of 11 (237 Views)
10-25-2012 07:12 AM in reply to: jmayo
Yeah. That's one reason I haven't notice it until now. Our convention is for all caps. Except I like to see the month in dates ad upper and lower. I've recently instituted that the iterations on a project should be in date format rather than Rev 1, Rev 2, Rev 3, etc. When things get complicate I feel an actual date helps.
Thanks.
Allen
jmayo
Message 8 of 11 (232 Views)
10-25-2012 07:40 AM in reply to: AllenJessup
I just went though this with one of our surveyors who doesn't like to make point groups for each days field work. What a PITA to decipher all the points in a multii-day job without a date and numbers that won't help either...
John Mayo, PE
IDSP 2014
AllenJessup
Message 9 of 11 (228 Views)
10-25-2012 07:53 AM in reply to: jmayo
We always have a point group for each day. Maybe he was working with a Survey Database and didn't know the trick of adding those points to a single point group.
Allen
jmayo
Message 10 of 11 (224 Views)
10-25-2012 08:32 AM in reply to: AllenJessup
No he knows how to do it. I think it is the old, 'my cad standards are better' or, 'they don't need this" routine.
John Mayo, PE
IDSP 2014
