Civil 3D Forum
Alignment Name Cap Style
10 REPLIES 10
Message 1 of 11
AllenJessup
566 Views, 10 Replies
This is strange. I wanted to label just the alignment name in a couple of places. I have an Alignment Name Label Style that does this. I now notice that it will capitalize some of the lower case P's in the curve label. Not the line label just the curve. They're applying the same style. It also changes back to lower case if I drag the label.
The style has one component and that is the Alignment Name and has Preserve Case set.
Allen
Allen Jessup
Engineering Specialist / CAD Manager
10 REPLIES 10
Message 2 of 11
BrianHailey
in reply to: AllenJessup
That doesn't look like a capital P to me. It looks like a lower case p that has been shifted up so the bottom of it lines up with the bottom of the rest of the letters. Can you put a capital P in the label somewhere so we can see how it compares?
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Message 3 of 11
AllenJessup
Brian,
Your right. Lower case P. It's also doing it with lower case J's,G's and Q's.
This only happens on arcs. The Label style isn't very complicated. I've tried changing the anchor point and attachment and that doesn't have any affect.
Allen
Allen Jessup
Message 4 of 11
jmayo-EE
Does it work correctly if you turn off the Curve Text option?
John Mayo
Message 5 of 11
AllenJessup
in reply to: jmayo-EE
Yes
Allen Jessup
Message 6 of 11
jmayo-EE
The curve text function is shifting everything to fit. I think this shifting would be less noticable with all caps. I would start a support case.
John Mayo
Message 7 of 11
AllenJessup
Yeah. That's one reason I haven't notice it until now. Our convention is for all caps. Except I like to see the month in dates ad upper and lower. I've recently instituted that the iterations on a project should be in date format rather than Rev 1, Rev 2, Rev 3, etc. When things get complicate I feel an actual date helps.
Thanks.
Allen
Allen Jessup
Message 8 of 11
jmayo-EE
I just went though this with one of our surveyors who doesn't like to make point groups for each days field work. What a PITA to decipher all the points in a multii-day job without a date and numbers that won't help either...
John Mayo
Message 9 of 11
AllenJessup
We always have a point group for each day. Maybe he was working with a Survey Database and didn't know the trick of adding those points to a single point group.
Allen
Allen Jessup
Message 10 of 11
jmayo-EE
No he knows how to do it. I think it is the old, 'my cad standards are better' or, 'they don't need this" routine.
John Mayo
Message 11 of 11
AllenJessup
I sent this in as an SR. Autodesk can duplicate it. Since there is no immediate fix they have closed the case but have passed it on to development. So I guess I wont be using lower case in Alignment names. Wouldn't for final documents anyway.
Allen
Allen Jessup
Rail Community
