Anyone know why the Alignment Layout Tools is greyed out?? This happens regularly and closing and restarting usually sorts it but not on this occasion
.....and I don't have any grips on the alignment when selected - don't remember seeing this before...???
neilyj (No connection with Autodesk other than using the products in the real world)
Solved by neilyj666. Go to Solution.
Solved by Joe-Bouza. Go to Solution.
Sounds like they are DS alignments?
Joe Bouza
Excellent - you've solved it...... I don't usually data shortcut alignments but I'm working on something after a few weeks and I'd forgotten that i had....
They are referring to data shortcut (DS) alignments/objects.
To edit a data shortcut, you just open the source drawing where the object was made.
Can be done by right clicking the object that is referenced and selecting "Open Source Drawing"
We have all been there
Joe Bouza
