The major and minor station alignment labels keep disappearing in my drawing. I've had some luck by removing and re-adding the labels but this has stopped working. Is this an issue that will be resolved by Service Pack 1?
There is a thread about disappearing Profile Labels. The workaround was to lock the Label layer immediately after creating. See if that helps with your alignment labels.
Allen Jessup
CAD Manager - Designer
I have certain alignment labels set to use an expression to set the text height. When I set the refference station (my 1+000 location) at an even multiple of 5 from the start of the alignment (ie the start point of the alignment is an even staion like 0+975) these staion labels don't display. My workaround is to start the alignment at something like 0+974.52. I generally turn off the labels prior to 1+000 anyway, so that part doesn't matter.
Mark Green
Working on Civil 3D in Canada
