Civil 3D Forum
alignment lable styles
3 REPLIES 3
willpyle7693
333 Views, 3 Replies
my alignment lable styles lable the beginning and end of the alignment in two different ways. I would like to get rid of the even foot station lable at the beginning and end and also possibly use some abbreviation other than "bp sta" and "ep sta". I am not able to figure out where i can change those or if it is even possible.
3 REPLIES 3
troma
in reply to: willpyle7693
Toolspace > Settings > (switch to 'Master View' if you're not in it) right click on drawing name
Edit Drawing Settings > Abbreviations
Here you can adjust the abbreviations used for many items.
I'm not sure what you mean by " get rid of the even foot station lable". Perhaps a picture would help?
Mark Green
Working on Civil 3D in Canada
troma
If you select your alignment in the drawing, right click and go to Edit Alignment Labels, you can set a start and end point for each label style assigned to your alignment. Maybe you can use that you remove the labels you don't want.
Mark Green
If you want to delete them, hold the CTRL key down and select them.  That way you can delete them independently from the other labels.
Todd Rogers
Rail Community
